!935 Ford Steering box - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-10-2011, 11:38 AM
Having a problem removing the steering shaft and housing from 35 ford sedan. How does it come apart from the steering box? Need help. dneddinger@sbcglobal.net
Old 11-10-2011, 12:16 PM
37Ford350's Avatar
35 steering box.
According to my 1935 "Motors Auto Repair" you have either a "GEMMER 1 (single roller) as opposed to the Gemmer 2. It only refers to the column and box assembly being attached to the car by the steering support at the dash and the frame bolts holding the box to the frame. (also the pitman arm). Because the steering shaft is attached to the "steering box" by means of an internal "worm" gear. Thus the steering column will not just slide out. It appears to me (to make it easier to work on) that the entire steering column with box will have to be removed from the car and the box disassembled to remove the shaft. This probably would be easier taken out from the bottom with the steering wheel removed. Of course you could go under the car and disassemble everything from underneith. The book is not at all clear. Maybe you can find additional information by Googling "Gemmer 1" steering box? Good luck.
Old 11-10-2011, 12:25 PM
Thanks for the information
55 Ford steering fairlaneguy Suspension - Brakes - Steering 1 09-07-2011 02:14 PM
56 Ford P/u w/351 W P/steering solidaxel Suspension - Brakes - Steering 1 04-07-2010 03:31 PM
Best steering for 32 Ford p/u 09bigboy32 Suspension - Brakes - Steering 3 09-10-2009 04:37 PM
steering on a 51 ford car 51FordDuff Suspension - Brakes - Steering 1 04-09-2006 05:19 PM
'52 Ford steering options slantws Suspension - Brakes - Steering 11 10-11-2005 04:55 PM
