We're winning the case!
Hotrodders Bulletin Board > Tech Help > Engine
  #1
Old 09-05-2008, 08:14 PM
hottrodz hottrodz is offline
94 350 chevy pu fuel problem
problem started when i put gas in tank, it idles but won't rev up, i replaced filter and plugs still won't rev past idle.
Old 09-05-2008, 10:31 PM
Canadian Mud Slinger Canadian Mud Slinger is offline
Chevy; A Mans Best Friend.
Try it with the fuel cap off?
Old 09-06-2008, 03:14 AM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
2nd Gunman On The Grassy Knoll
My fathers 98 chevy pick up did this same thing about 3 weeks ago. The electric fuel pump failed. We did a pressure check and it had 20 psi, it was supposed to have 55 psi. The truck would start and idle, but would shake real bad, and it wouldn`t rev at all, you press the pedal all you wanted and the engine wouldn`t come off idle. Check your fuel pressure.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "94 350 chevy pu fuel problem"
Power and Fuel Econ Porblems with NEW STOCK 1994 350 TBI MuscleBlock81 Engine 12 09-08-2009 11:01 PM
Still Having Fuel Flow Problem to QJet JohnTN Engine 5 09-06-2008 03:10 AM
Making the chevy 350 v8 more fuel efficient? k3werra Engine 27 07-14-2007 02:10 AM
1988 chevy Fuel Injection Problem 52Ford Electrical 11 10-26-2006 05:28 PM
Need Help With Vss Problem 99 Chevy Pu NAIRB Engine 12 01-09-2005 06:33 PM
