Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 94 350 hesistating
Old 04-09-2012, 03:36 PM
badjeebus badjeebus is offline
hello, the truck came with the 94 350 in it, i put the new tbi on it , new base gaskets etc,engine is stock as far as i know , no modifications, no headers or anything like that,,,,i assuming the o2 are good, no codes flashing on the dash,doresnt make a difference if the engine is warm or cold,, still does it,,,,,i dont want to start just replacing all the sensors until it stops, it seems to be in the range just above idle , you can push slightly on the gas pedal above roughly around 1000 rpm and up a little and it hesitates and seems to run rough i say miss but its not backfiring or anything like that,then once above 1800-2000 rpm it smooths out and is fine,just not sure what to do next,thanks again for all your comments and help ,much appreciated
