94 4L80-E trans from a 4x2 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-28-2010, 03:41 PM
rbp rbp is offline
hi everybody... can I use a '94 4L80-E trans from a 4x2 remove the tailshaft and bolt it to a '95 4x4? (same engine, same trans just diferent drive)
Old 01-28-2010, 05:23 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
nope, 4x4 shaft and a 2 wheel drive shaft are different
Old 01-28-2010, 10:52 PM
rbp rbp is offline
thanks! I have the idea but I wasn't sure...
chevy 1500 4x4 trans into a 4x2 hellraiser509 Transmission - Rearend 4 12-30-2009 11:27 AM
4L80 yoke in a 4L60 trans ? Billvill Transmission - Rearend 3 05-07-2007 08:54 PM
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 02:14 PM
1973 Olds Omega trans question Mr442W-30 Transmission - Rearend 4 02-22-2003 08:18 PM
late model auto trans question crazy larry Transmission - Rearend 2 11-23-2002 09:20 AM
