Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 94 c1500 Tranny swap
Old 09-25-2012, 04:15 PM
Valkyrie5.7's Avatar
Valkyrie5.7 Valkyrie5.7 is offline
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
Originally Posted by joe_padavano View Post
Assuming you have a 200-4R with the universal bellhousing (some were BOP only), yes it will bolt to the motor. Unfortunately, that's all you can do. The original 700R4 is a different length, so the crossmember and driveshaft are different. Your VSS may or may not fit the 200-4R either. After all this trouble to swap it, at least you'll have a trans that is probably too weak for your application, so you'll get to swap it again in a few weeks.
+1. I'd also like to add that you'll probably be missing the deep first gear the 700r4 has if you actually use it as a truck compared to the 2004r. Also a 94 has a 4L60E right? If so, I hope you have a manual transmission ECM.
