94 c1500 Tranny swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-25-2012, 01:36 PM
Hey guys I was wondering if I could put my Th2004r tranny into my c1500 as the ranny thats in the truck is acting up. Will the 2004r bolt right up and work with no issues. there both 4 speed overdrives. If not what will I have to do??
Thanks for the help
Old 09-25-2012, 03:17 PM
Thanks for the help
Assuming you have a 200-4R with the universal bellhousing (some were BOP only), yes it will bolt to the motor. Unfortunately, that's all you can do. The original 700R4 is a different length, so the crossmember and driveshaft are different. Your VSS may or may not fit the 200-4R either. After all this trouble to swap it, at least you'll have a trans that is probably too weak for your application, so you'll get to swap it again in a few weeks.
Old 09-25-2012, 04:15 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
+1. I'd also like to add that you'll probably be missing the deep first gear the 700r4 has if you actually use it as a truck compared to the 2004r. Also a 94 has a 4L60E right? If so, I hope you have a manual transmission ECM.
1989 to 1998 Chevy C1500 Sidestep Engine Swap. 89SideStepMan Engine 8 09-13-2010 06:45 PM
1993 gmc c1500 disk brake swap cusz28 Suspension - Brakes - Steering 4 01-08-2010 02:38 PM
97'C1500 4L60e tranny problem fiolater Transmission - Rearend 3 03-23-2008 07:27 AM
86 K10 engine swap! swap tranny too? big_e111 Transmission - Rearend 3 08-03-2007 01:21 PM
92 C1500 engine swap littleblue92 Engine 6 01-01-2007 11:43 AM
