94 camaro build - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2011, 09:24 PM
94 camaro build
hey everyone i got a 1994 camaro z28 set up for a gen 1 small block it had low compression in the 3 and 5 cylinders so i pulled the motor to rebuild and started looking at the part numbers and its a 350 block bored 0.20 over with a 327 crank 3.25 stroke making it a 331 and im wondering which would be better the 331 or 355 i heard you can take a 331 up to 8000rpms but dont know much about it i plan on running forged pistons and forged 6.0 rods any info would help thanks
Old 05-09-2011, 10:13 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I can tell from your post that you have no idea how much money it takes for parts to be able to twist to 8K and stay together for more than one time. Are you planning to race this motor? Why forged pistons? Why 6" rods? If this is stuff you've read about in the magazines or heard someone down at the Sonic DriveIn talk about, you need to come back down to Earth and tell us what you want the motor to do. Be real.
1980 camaro Z28 engine build help machinestheman Engine 15 06-30-2010 06:13 AM
67 Camaro -Valve Train noise after Build RMoore2225 Engine 18 06-09-2008 08:15 AM
79 camaro hood hinges to 71 camaro swap Gladis Body - Exterior 1 01-10-2008 02:17 PM
200-4r experts - build questions - Which core is best to build on? Warrant Transmission - Rearend 7 10-09-2007 07:36 PM
1991 Camaro RS 350 build ahouse89 Engine 3 06-08-2007 12:55 PM
