94 camaro with v-6 5 speed 350 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2011, 07:45 AM
Hello, I have a 94 camaro with a v6 and 5 speed, will a chevy 350 bolt up to the 5 speed bellhousing and what other issues will i have. Thanks
Old 05-29-2011, 09:25 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
The five speed won't bolt up to the 350. Different bellhousing completely.
I suggest finding a donor 94-95 camaro and get the whole engine, computer, wiring harness, transmission, the works.
Old 05-29-2011, 09:46 AM
Wiki Edits: 31
Yep, and a bellhousing swap won't work, because the input shaft is diffrent
Old 05-29-2011, 04:37 PM
DoubleVision's Avatar
I recommend finding a V8 car to start with. Don`t waste the money you`ll invest converting the car over as it`ll need more than just the engine and tranny swap, it`ll also need V8 front coil springs and hordes of other odds and ends.
Best 4 Speed in 67 Camaro 97laynlow Transmission - Rearend 6 01-12-2010 07:09 AM
camaro 1990 transmission swap? 5 speed ? hondaca Transmission - Rearend 0 08-13-2008 02:14 PM
79 camaro hood hinges to 71 camaro swap Gladis Body - Exterior 1 01-10-2008 03:17 PM
T56 6 speed in a '79 Camaro bigblock454camaro Transmission - Rearend 1 11-21-2006 08:42 PM
Clutch problems 95 camaro 5 speed namdlo Transmission - Rearend 1 06-22-2004 10:39 AM
