94 chevy 1500 tranny problem.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-17-2011, 11:15 AM
First I would like to say hello and what a great site!
I have a 94 Chevy 1500 with a 5.7l and a shifting problem. When I put the truck into OD or D the trans wont shift out of 1st gear. but it will go into second gear when I do it manually on the column. It will not go into a higher gear from that point on. I want to know if it is a electronic problem or if it is a mechanical problem. I don't want to pull the trans if its not necessary. But.... I think it might have to happen. It does go into reverse no problem.
Old 04-17-2011, 11:20 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Miles on the transmission? Original trans If known?
Does the speed-O work?
cheeck engine lite on in the dash?
There is a large round electrical connector on the passenger side of trans... just above pan rail.
If you unplug that connector , the trans should default to 3rd gear with shifter in OD or D ..
Or pul the proper fuse from the panel that feeds the trans power.
A quality scanner than read more than simple codes would help too
Old 04-17-2011, 11:21 AM
The mobile view is crap
possibly the Vehicle Speed Sensor located on the tail of the trans or the tail of the transfer case if it is 4 wheel drive.
Old 04-17-2011, 11:37 AM
its a 2wd, that round plug on the passanger side might have been unpluged, its loose for sure. I took it out an plugged it back in and I will try and see if there is a problem still. I will also try pulling the fuse that feeds the trans power. As for the speed sensor. I just put a different one in, the old one was leaking from the tail, the o-ring was gone out of it.
Old 04-17-2011, 11:41 AM
i also noticed that the speed-o bounces when it is in park and the truck is running, but when it starts to move the speed-o seems to work fine
Old 04-17-2011, 11:52 AM
Has it gotten better when you changed the vehicle speed sensor? I would relate the speedo bouncing to the vehicle speed sensor
1985 chevy 4x4 tranny problem in 3rd gear 85chevystepside Transmission - Rearend 1 08-31-2010 10:58 PM
Ram 1500 Tranny slips Ramrunner Transmission - Rearend 1 07-17-2010 03:56 PM
s10 into 1500 tranny swap hellraiser509 Transmission - Rearend 6 12-23-2009 03:43 PM
1964 chevy C-10 has a 700r4 tranny problem trx9 Transmission - Rearend 3 06-07-2009 10:53 AM
My 1996 Chevy Z71 CK 1500 tranny SULLY 1 Introduce Yourself 1 11-15-2004 08:32 AM
