Originally Posted by hpete
A blown or missing fuse acts the same as what your describing. The red wire should be hot (12volts) whenever the ignition is on.
have 12 volts red wire on harness as well as 12 volts inside on internal harness when key is on fuse is good checked voltage at both sides ov fuse 12 volts
