94 chevy 4x4 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-21-2012, 07:51 PM
94 chevy 4x4 4l60e
only have 2nd and 3rd and reverse
this is a new trans 0 miles, have replaced pcm/ecm, tps sensor, temp sensor, pulled wiring harness checked for bad wires all have good continuity,at wits end here any help would be great......
Old 06-21-2012, 08:14 PM
A blown or missing fuse acts the same as what your describing. The red wire should be hot (12volts) whenever the ignition is on.
Old 06-21-2012, 08:42 PM
re 4l60
have 12 volts red wire on harness as well as 12 volts inside on internal harness when key is on fuse is good checked voltage at both sides ov fuse 12 volts
Old 06-22-2012, 06:57 AM
You can pull the codes on a 94 with a paperclip, I'm posting from my phone so I really can't do any research but I'm thinking 1-2 solenoid. But check the codes before you buy any parts!!!
Old 06-24-2012, 09:12 PM
no codes present checked with snapon scanner has erratic speed from sensor replaced that still no 1st or 4th only 2nd and 3rd again this is brand new dyno tested trans from tci
Slow shifts 03 Chevy S10 ZR2 4x4 4.3L 4l60e 139k mi mike 96 ws6 Transmission - Rearend 19 02-27-2012 06:33 AM
4L60e 4x4 to 2x4 bonuts Transmission - Rearend 1 10-02-2010 02:26 AM
4l60e shift problem, 99 chevy taho 4x4 king8403 Transmission - Rearend 3 02-13-2008 11:34 PM
4l60e 4x4 To A 4l80 ??? roxxxi Transmission - Rearend 1 11-01-2007 07:54 PM
4L60E 4x4 tarmon8r Transmission - Rearend 0 03-10-2006 07:47 PM
