Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 94 chevy truck maybe dist./ignition problem,please help!
Old 10-25-2004, 05:09 AM
RCastle's Avatar
RCastle RCastle is offline
Come Home Safe Soldier
Last journal entry: Headers
Check the wire running from your battery to your box,is it hot?If not the terminal may have come loose.
Check to make sure you have voltage to your coil from the box,I have a 6AL in my Malibu,no diff than a 6A except I have rev chips,the hot side terminal got loose from my engine shaking and broke the connection,caused the engine to run like it was a burned plug wire on the header.I replaced the eyelet on the + and - side of the coil,fired her up and she ran correctly.
