Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 94 Dodge Transmission Electronics problem?
Old 11-25-2003, 07:31 AM
airworld2's Avatar
airworld2 airworld2 is offline
dodge tranny
42 le(606) transmission,as it is called you should have it scanned to be sure but sounds like you have already found the trouble with dash lights. that would most likely be the mvlps (manual valve lever positions switch) which in on the inside of tranny pan on valve body. no easy for diy tranny shop would be your best place for this..
