94 explorer axle are they lim. slip or ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2009, 01:47 PM
fast68's Avatar
likes chevy trucks & boobies
replacing a bad rear axle under a 94 explorer 4x4 with another one right now here and it will need to be filled with oil
what viscosity oil and are these lim. slip ??
cant seem to find out anything anywhere about these things.. hmm...
Old 11-02-2009, 02:14 PM
prostreet6t9's Avatar
Differential/Driveline
Look behind the side gears and see if there is any clutch's.
80/90 will do fine and some additive if you have a L/S.
Old 11-02-2009, 02:20 PM
Wiki Edits: 31
check the axle tag.. IIRC an L in the ratio will mean it's LS.. so it would read like L373 or L410 but if it's not, It would just read 373 or 410.. some have the numbers spaced out and some don't depending on year so it could read L 3 73
Old 11-02-2009, 02:29 PM
fast68's Avatar
yeah 3L23
and 3.27 is the ratio
looks like additive is needed hmm
thanks
Old 11-02-2009, 03:02 PM
It's usually a good Idea to pull cover and double check especially if your working on 4X4. I've seen many times that the tag on the Differential didn't match what was inside.
Old 11-02-2009, 03:33 PM
fast68's Avatar
its fine
done
just test drove it
took 3 hours to swap out
thanks
Axle question, 89 mustang/91 explorer eatonde Transmission - Rearend 3 01-17-2009 06:44 PM
94 explorer fule pump failure jrjeb Electrical 10 07-13-2006 01:04 PM
94 explorer alarm jrjeb Electrical 1 05-24-2006 03:07 PM
Axle Information. M&M CUSTOM Transmission - Rearend 1 02-21-2005 01:37 PM
1938 chevy 6" drop axle for sale landon4421 Suspension - Brakes - Steering 0 09-26-2003 04:20 PM
