-   -   94 F150 axle code question (http://www.hotrodders.com/forum/94-f150-axle-code-question-210001.html)
boss68 12-08-2011 06:28 PM
A friend just left with a question about the axle code on the 94 F150 4x4 just purchased.
The bottom row on the tag reads 3L55 88 3L08
He is looking to replace the rear end and needs to know if it is a 3.55 gear or a 3.08?
Any info would be helpful.
Thanks
matt167 12-08-2011 06:33 PM
that's odd. it's a limited slip but your right, it could be ither or.. check the door tag
boss68 12-08-2011 06:40 PM
That's the only thing that seemed to be logical .
I believe he checked the door and it implied a 3.55.
Thanks!
MadMacs 12-08-2011 06:43 PM
Yeah 3.55... center number is for an 8.8 axle and last code is the plant stamping
boss68 12-08-2011 06:46 PM
Great, i will let him know.
:thumbup:
66GMC 12-08-2011 06:59 PM
Ignore this one.
Accidentally double-posted due to server traffic and editing.
66GMC 12-08-2011 07:01 PM
Tag is USUALLY (IMO / IIRC) in the ratio, ring gear dia, date-code format.
3L55 should be 3.55 "Locking" diff with an 8.8" Ring Gear
You didn't say what was on the top row of that tag ... but
Fordification may be able to decode that for you.
The index is at the bottom of the page
boss68 12-08-2011 09:00 PM
That chart does it Thanks :thumbup:
