94 F150 axle code question - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-08-2011, 07:28 PM
A friend just left with a question about the axle code on the 94 F150 4x4 just purchased.
The bottom row on the tag reads 3L55 88 3L08
He is looking to replace the rear end and needs to know if it is a 3.55 gear or a 3.08?
Any info would be helpful.
Thanks
Old 12-08-2011, 07:33 PM
Wiki Edits: 31
that's odd. it's a limited slip but your right, it could be ither or.. check the door tag
Old 12-08-2011, 07:40 PM
That's the only thing that seemed to be logical .
I believe he checked the door and it implied a 3.55.
Thanks!
Old 12-08-2011, 07:43 PM
Yeah 3.55... center number is for an 8.8 axle and last code is the plant stamping
Old 12-08-2011, 07:46 PM
Great, i will let him know.
Old 12-08-2011, 07:59 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Ignore this one.
Accidentally double-posted due to server traffic and editing.
Old 12-08-2011, 08:01 PM
66GMC's Avatar
Tag is USUALLY (IMO / IIRC) in the ratio, ring gear dia, date-code format.
3L55 should be 3.55 "Locking" diff with an 8.8" Ring Gear
You didn't say what was on the top row of that tag ... but
Fordification may be able to decode that for you.
The index is at the bottom of the page
Old 12-08-2011, 10:00 PM
That chart does it Thanks
Rear axle code Bill65 Transmission - Rearend 7 08-07-2014 03:02 PM
Ford rearend axle tag ID code question aztlanco Transmission - Rearend 9 12-28-2009 02:48 PM
Rear axle code bodriver953 Transmission - Rearend 1 11-02-2009 08:23 PM
Axle code ID, help to decode? curtis73 Transmission - Rearend 1 05-21-2006 04:59 PM
axle code s johnsquicks10 Transmission - Rearend 3 05-12-2005 09:25 AM
