94 firebird: What's needed to delete Fuel Injection - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-26-2006, 04:54 PM
I picked up a 94 Firebird with the 5.7 LT1...It had an upper engine fire. I'm wanting to make a drag car out of it. My questions are:
What are the main issues to look for when taking off all the computer controls, fuel injection, etc and just running a regular manifold and carb set up? Would the ignition still work with the key or would I by pass that with a push button?
Does the 4L60E tranny have a separate computer that controls it or is it the same computer that runs the engine/fuel injection, etc.
Would I need to use a different fuel pump.
anything else? THANKS!
Old 10-27-2006, 04:39 PM
Anyone? Anyone?
Old 10-27-2006, 04:47 PM
Wiki Edits: 31
if it's a drag car, get a new painless wiring harness. LT1 carb manifold, and a stand alone 4l60E controller.
Old 10-27-2006, 07:05 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The starting place is get a copy of the NHRA rules..some apply to electrical systems..
If you had an upper engine fire in the engine bay, scrap the wire harness all together and start anew.You can't tell what has melted and shorted together from the heat inside the taped bundles..
You need to consider the following:
  • Where to locate the battery, front or rear?
  • Will a remote start solenoid be used?
  • Where the emergency Disconnect will be mounted?
  • Will lighting be used?
  • Will a charging system be used?
Then you need to decide Bare Bones or stock instrumentation? (scrap panel and go aftermarket, or stay stock..)
You need to consider:
  • Starting system
  • Charging system (if one is to be used)
  • Ignition System
  • engine monitoring group
This is bare bones..and minimum wire count..preferable for Strip only..Then plan your harness from there.
Doc
Old 10-28-2006, 10:33 AM
Thanks Matt...that's what my question was, was if the tranny needed its own computer. I've been drag racing off and on for over ten years so I'm not new to the rules and all that. My question was specifically to this car, what needs to be done to take the computer and fuel injection out.
Does anyone know about the fuel pump?
Old 10-28-2006, 04:19 PM
Wiki Edits: 31
the fuel pump likely puts out 15-30 PSI, you could regulate that down to 7 PSI with a carb fuel pump regulator, to run a carburator
fuel injection turned into a carb engine schuffman Engine 3 02-28-2006 01:13 PM
How much HP Stock Fuel Injection? nitrous_69stang Engine 1 12-15-2004 08:10 PM
Fuel pump/sender needed, which one? guba_unus Engine 1 10-18-2004 10:02 PM
Help needed to calculate fuel used... HXStatesman Introduce Yourself 0 09-02-2004 10:27 AM
Carb or fuel injection dragon wagon Engine 3 03-05-2004 02:02 AM
