Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 94 ford engine swap timming
Old 08-03-2012, 10:39 AM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
pull SPOUT connector out of plug. start engine. Adjust timing to 10* BTDC. Shut engine off. Plug SPOUT in, start engine and you are done. You may run into some issues with the ECM, as it is calibrated for a 5.8, and you now have a 5.0.
The Following User Says Thank You to sbchevfreak For This Useful Post:
chford (08-04-2012)
