-   -   94 ford engine swap timming (http://www.hotrodders.com/forum/94-ford-engine-swap-timming-222499.html)
chford 08-03-2012 09:56 AM
I have a 94 Ford it came with the 5.8 engine blew now I got the 5.0 and I can't seem to figure out the timing and how the spout works I have no clue what to do
bigdog7373 08-03-2012 10:19 AM
Can you be more specific
sbchevfreak 08-03-2012 11:39 AM
pull SPOUT connector out of plug. start engine. Adjust timing to 10* BTDC. Shut engine off. Plug SPOUT in, start engine and you are done. You may run into some issues with the ECM, as it is calibrated for a 5.8, and you now have a 5.0.
http://api.viglink.com/api/click?for...13157203182861
chford 08-03-2012 06:19 PM
Thanks alot its been giving me gray hairs what should I expect from the ecu I have the eec iv
