94 ford engine swap timming - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2012, 08:56 AM
I have a 94 Ford it came with the 5.8 engine blew now I got the 5.0 and I can't seem to figure out the timing and how the spout works I have no clue what to do
Old 08-03-2012, 09:19 AM
bigdog7373's Avatar
Of course it's fast
Can you be more specific
Old 08-03-2012, 10:39 AM
sbchevfreak's Avatar
Licenced Automotive Technician
pull SPOUT connector out of plug. start engine. Adjust timing to 10* BTDC. Shut engine off. Plug SPOUT in, start engine and you are done. You may run into some issues with the ECM, as it is calibrated for a 5.8, and you now have a 5.0.
The Following User Says Thank You to sbchevfreak For This Useful Post:
chford (08-04-2012)
Old 08-03-2012, 05:19 PM
Thanks alot its been giving me gray hairs what should I expect from the ecu I have the eec iv
Need advise on Ford 300 engine swap to a Ford 400 aztek_warrior Hotrodding Basics 6 03-22-2011 02:59 PM
54 Ford engine swap Straycat631 Engine 1 07-31-2010 09:32 PM
Timming Issue, 350ci--- Engine Dies!!! gman536 Engine 11 12-28-2009 08:15 PM
95 ford F-150 engine swap, Same Transmission fit new engine? F-150 Transmission - Rearend 5 10-07-2007 12:11 PM
engine timming nrichardson Engine 3 11-25-2002 03:29 PM
