94 GM 3800 oil pump pressure spring and valve - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2006, 02:02 PM
motoxracer's Avatar
Hi
On a 1994 GM 3800 want to know in what direction the spring and valve go Im assuming spring goes into the timimg cover and the valve with the cavity goes over the spring and oil filter housing cover on top is this correct someone plese let me know
Old 03-14-2006, 04:24 PM
Rev It Loud, Drive It Proud!
You are correct sir..
Old 03-14-2006, 08:12 PM
motoxracer's Avatar
Thanks
Thanks for the confermation
How to properly mate a GM pump to a Mustang II rack Centerline Suspension - Brakes - Steering 73 10-31-2009 11:59 AM
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Oil Pump Trick 57NAPCO Engine 20 08-02-2005 12:47 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
Lean backfire Camaro76 Engine 5 04-15-2003 05:45 PM
