94 GMC Yukon Torsion Bars (Lowering) - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2010, 07:48 PM
I have a 94 GMC Yukon that I want to drop the front end 2". It has torsion bars and I want to know if I can drop the front end with the stock "keys" or do I have to order the lowering "keys?"
Old 11-27-2010, 08:02 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
You should be able to get close to the 2" you are after with the OE keys. Each rotation of the adjusting bolt is approx. 1/8"
Jack it up, support the frame, let the wheels hang to take the tension off of the bolts, then back them off. I usually leave them 1-1 1/2 turns tighter from no contact between the bolt and the key. Check for equal ride height from side to side on level ground.
The keys are needed when you start looking for 3-4" drop.
Lowering Truck with torsion bar front suspension jtbaca Suspension - Brakes - Steering 2 09-04-2010 10:27 AM
Lowering a 74 GMC 1500 TiMeWaRp Suspension - Brakes - Steering 11 01-15-2008 10:26 PM
lowering blocks and traction bars?? 47chevrolet Suspension - Brakes - Steering 4 09-28-2007 03:53 PM
relocating torsion bars cojohnso Suspension - Brakes - Steering 2 12-15-2004 05:56 AM
6 cyl vs. 8cyl torsion bars? bclulee2000 Suspension - Brakes - Steering 2 09-05-2003 11:34 PM
