94 grand prix turn signal problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2007, 02:45 PM
I cant get the turn signals to work on my 94 grand prix the indicator comes on one side but not the other and it doesent flash. The front lights in the bumper dont come on at all and the bulbs seem fine? My brake lights work fine except the upper one in the back window i changed those bulbs and it still dont work. I changed the flasher it made no differance. Is there anything else i can try before changing the turn signal switch? thanks
Old 01-06-2008, 03:03 PM
sedan delivery's Avatar
signals
you have had this posted for a while now. you may have all ready fixied it by now. but if you havent you can check the connections under the dash where the harness come together for the signal switch. use a test light to check for power th the side that is not working. i think you have a bad signal switch...
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
Turn signal switch on column 49dream Suspension - Brakes - Steering 1 04-27-2005 08:00 PM
Turn signal flasher Seon Electrical 10 12-05-2003 10:34 AM
need turn signal switch & advice --help! : ) WayOutCat Electrical 8 05-01-2003 10:56 PM
1968 firebird turn signal phoenix Electrical 6 08-07-2002 08:40 PM
