94 jimmy stuffed with a 350 v8 love it - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2010, 08:39 PM
Hey guys, I started a project for my son, Doing a V8 swap on a jimmy. It really is a project. I managed to jump all the obstacles pretty cheap. But one thing I will be coming to is the alternator, I want to be able to plug in an alternator for a V8 with the stock V6 harness. My 94 GMC full size pick up does not have the same plug. Anybody else done this? Any suggestions?
Old 08-22-2010, 09:39 PM
ericnova72's Avatar
More for Less Racer
I'd use the alternator from the V6, it should be the good CS-130 style.
Conversion plugs for almost any style alternator are available at many parts stores. you can also try Mad Enterprises www.madelectrical.com
Old 08-23-2010, 09:44 PM
thanks thats the stuff im tring to find out .you didnt have charging problem thats good stuff. i tried this before and had charging trouble to hard on the battery.i'll check that stuff out .thanks alot
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 04:00 PM
Reconditioning a small block 350 chevy v8 Butchardos Engine 1 03-24-2003 11:28 PM
94 350 tk timing @ proseadure smills192@cox.net Engine 1 01-20-2003 06:31 PM
Cold run/fuel enrichment for '94 Chev 350? FlyB58 Engine 4 01-04-2003 08:54 AM
72 Chevelle 350 v6 or v8? MYNAMEIZCARLOS Hotrodders' Lounge 4 12-14-2002 07:07 PM
