94 K Blazer won't go into drive, sometimes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2006, 05:38 PM
57 Chevy's Avatar
My daily driver, 94 full size Blazer, will back out of the drive fine. Put into drive and nothing, for about a minute then it engages. It also may do that on the first one or two stops. After that it shifts fine. I know it's cold (3 degrees) in Montana, but I keep thinking that something is stuck, but what?
Old 11-29-2006, 06:21 PM
Crosley's Avatar
Wiki Edits: 1659
hard internal seals would be my first guess.
Did the vehicle drive 'fine' till the real cold temps hit town?
Old 11-29-2006, 06:22 PM
94 K Blazer won't go into drive,sometimes
Now that I'm getting a little older I don't move so well in the cold either.
You may have hard seals,fluid warms up expands the seals,I'm sure you have checked the fluid level,so I won't ask.
Tomorrow try pulling in into manual low,see if it moves then,please post back with results.
Old 11-29-2006, 06:33 PM
airworld2's Avatar
k5
try adding 1oz of good old brake fluid, soften up hard rubber and no damage to other parts as do many so called fix it in a can. oh by the way adding more than 1 oz will not do better things a little goes along way here . fluid level sounds to be low as others stated.
Old 11-29-2006, 08:14 PM
Crosley's Avatar
Wiki Edits: 1659
A quart of 10-40 motor oil may help too.
Old 11-30-2006, 07:48 PM
57 Chevy's Avatar
I'll start with a filter change and go from there. It did this twice in warm weather about 6 months ago. I was thinking that a valve or solenoid might be sticking.
Old 11-30-2006, 08:34 PM
Crosley's Avatar
Wiki Edits: 1659
you can completely unplug the electric from the tranny.... and it should go into gear (R or OD, D) quickly.
Although ... with the tranny unplugged.... it will default to 3rd gear .
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
info transfer form old hard drive to new ChevelleSS_LS6 Hotrodders' Lounge 6 03-02-2005 04:06 PM
Silverado Blazer 305 Project william27103 Suspension - Brakes - Steering 1 10-18-2004 04:16 PM
Erson Gear Drive Woes blndweasel Engine 9 07-14-2004 09:53 AM
350/350 not getting out of drive MRGM Transmission - Rearend 11 04-28-2004 10:48 AM
