94 Mustang air bag help needed! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 01:30 PM
frankenvette's Avatar
Go ahead kid squeeze the wheez
My son had a front end collision in the 94 Mustang. We have all repaired and replaced the air bags and controller. Still getting the air bag light on. I did not replace the sensors on the front end, didn't think this was neccessary. Am thinking the computer needs to be reset? Any ideas?
Old 10-21-2005, 11:07 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Not a Ford guy at all..
But here is the procedure for repairing/resetting the SRS on a 94 Stang..
http://www.autozone.com/servlet/UiBr...3d801dd7bc.jsp
Hope it helps!
Or maybe one of our Good Ford Tech's out here can offer more!
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-22-2005, 08:44 AM
Thanks Doc. I did all that and still have the bag light illuminated. When I replaced the bags and module, I did the proceedure described and thought I had it. The diagnostic takes place, the light goes out, then comes on continually shortly thereafter. I am betting there is a way to clear the light in the computer, but have no idea how.
Old 10-22-2005, 04:22 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
One thing I did note while reading that..It says if you got in a front end Fender bender, and deployed the air bag, get a steady lamp, you need to have it inspected by a tech, or replace the sensor..maybe that's what you need to do to reset the system..(Or pull the bulb out.. )
Doc
Innovations
Old 10-22-2005, 05:23 PM
aka Duke of URL
Listen,
I have been following this post and unless you have been factory trained on SRS, you at least need the appropriate year shop manual. The system is tested with simulators in place of the bags to prevent accidental deployment. Full diagnostic procedures are described in the manual.
FORD Shop Manuals (CD Format) can be found fairly cheap on E-Bay.
Old 10-22-2005, 07:06 PM
I believe the sensors are the issue, but haven't found them anywhere yet. They are replaceable, have a connector under the wheel well, just haven't located any. I have a dealer parts manual and they are listed, so I'll try a dealer.
Air Ride Bag Speed black66 Suspension - Brakes - Steering 11 09-12-2005 07:29 AM
67 mustang ignition wiring help needed 6t8stang Electrical 2 12-24-2004 11:14 AM
mustang II streering rack help needed stea Suspension - Brakes - Steering 4 07-22-2003 11:12 PM
does a 351 fit in a 94 mustang? 351mustang02 Engine 9 07-12-2003 12:44 AM
Air bag suspention 1970CDV Suspension - Brakes - Steering 1 04-25-2002 04:18 PM
