94 Mustang rear end info - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2006, 02:08 PM
Anyone know whether a 6 cylinder 94 Mustang has a 8.8 or a 7.5 rear end? How do you tell the difference between the two?
Old 05-18-2006, 10:04 PM
Probably a 7.5". The 7.5" rear end cover is flat on the top & bottom, and curved on the sides. The 8.8" is kinda flat on all 4 sides, with curved corners.
#3 is an 8.8", #4 is a 7.5"
Old 05-20-2006, 01:29 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
No 8.8's in V6 Mustangs. Note in the above pictures #3+#4 above you can see a little metal tag under a top right bolt. These tags make it easy to ID what you are looking at. The second row of letters will look something like "2 L .73 8.8" and a couple more numbers. In this case it would be a "2.73" ratio. The "L" stands for a traction-loc rear (much rarer than a regular "2.73"). And of course "8.8" signifying that it is an 8.8" rather than a "7.5".
Easy peasy. As long as it hasn't been eaten up by rust or some butthead pulled the tag off and threw it away.
Rear end swap required & I'm cunfussed datsun dale Transmission - Rearend 8 12-17-2008 09:03 AM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
S-10/Camaro Rear End slaveforthewave Transmission - Rearend 7 02-20-2006 01:44 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
