94 ranger stripped distrib gear, set base timing? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2010, 12:09 PM
fast68's Avatar
likes chevy trucks & boobies
ok well so we got this 94 ranger in here and well the kid that owns it is from carbondale and is stranded up here until i get this thing going again for him if nothing else is wrong with it anyways
over the years ive heard of distrib gears that wear and strip
and well ive never come across one ever
until now.
it really fooled me when it showed good compression and good fuel but only a spark every now and then from a plug wire
so i tried another ICM
and of course that didnt change anything
so i was like *** is going on here
saw something on the internet about distrib gears stripping and it reminded me, so i went ahead and checked the rotation of it with the crank and it seemed ok, until i picked up on the distib shaft and found that i could rotate it!
uh oh..
so yeah i got a good used distrib from tyhe junkyard sitting here and im about to set it to number one TDC of the CS
now, on the harness to the ICM there are two red wires coming out of it there and a gray shunt thing plugged into a smaller black connector just for these two wires.
are these the wires for setting distrib timing to zero? do you set these fords to zero degrees base timing?
if not then how do you set base timing on these? what do i need to unplug or ground?
if theres anything else i need to know then tell me now
this is the style with pickup magnet in the distrib, and the ICM is on rad support behind driver headlamp
1994 ranger 3.0
thanks
Old 11-01-2010, 01:25 PM
fast68's Avatar
ok well dropped in distrib with #1 TDC CR and it dont work
tried 180 opposite around the cap with the wires and still dont run
ok *** is going on here
omg...
do these have to be indexed in some stupid way like the jeep 4.0L and some others are ?
man..
so close yet so far away,,
Old 11-01-2010, 02:43 PM
Wiki Edits: 31
lemme check... actually, they do need indexed, and 3.0's are known for eating the distributors/ cam syncs. usually they stop the oil pump drive and lock it all up... there is a way to index it manually, but I'm pretty sure theres a tool also
Old 11-01-2010, 06:41 PM
fast68's Avatar
figured it out finally almost a couple hours ago wow it was fun
nice that they put that damn timing mark line on the balancer but it has nothing to do with setting the distrib timing or TDC #1
bastards..
running good , just got back from a drive in it
thanks
94 Ford ranger drop 4" 94ranger Suspension - Brakes - Steering 1 06-18-2009 10:34 PM
1997 Ford Ford Ranger gear ratio ? mercury man Transmission - Rearend 8 03-23-2008 02:10 PM
98 ranger / 5R55E gear ratio error codes tnsmith10 Transmission - Rearend 4 05-27-2006 06:43 AM
94 ranger fan clutch adrock430 Engine 1 02-22-2005 02:47 PM
94 ford ranger 3.73 posi Help? fatherandson53 Transmission - Rearend 2 10-28-2003 11:11 PM
