94 S-10 manual trans problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2012, 08:29 PM
Was offroading and tried to go to 4WD-hi but the light didn't come on. In fact no lights - even when tried to go back in 2WD. So drove home 60 mph about 120 miles when came to stop and then everything was like neutral -- all the gears. Roadside help replaced the electronic switch and got me moving but I'm left with:
*Reverse works fine
*can start out in 1 or 2 no problemo, then shift to D or OD and all is well
*cannot start out in D or OD
*come to stop or slow below 20 mph in D or OD and is like neutral
*NO Engine warning/service lights come on
One mechanic told me low roller clutch and forget it, keep shifting manually.Another told me it was BhiftB solenoid needed replacement.
Now the 4WDhi is not activating... hmmm.
Any suggestions?
Old 09-30-2012, 06:46 PM
pricesgarages's Avatar
yourpost said manual trans a manual dont have soleniods or roller clutches but if yours a auto it sounds like the the fwd sprag failed wich is internal issue the 4x4 problem is seperate
s10, transmission
s-10 manual trans question ds-unique Transmission - Rearend 2 05-30-2008 09:20 PM
Help me with a manual trans... SecGenLvr Hotrodding Basics 2 02-16-2006 05:03 AM
manual trans problems 87442lover Transmission - Rearend 5 09-02-2004 10:11 PM
need help with manual trans ID Scuzzy Transmission - Rearend 3 10-02-2003 12:27 AM
