94 s10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2007, 07:46 AM
runn141's Avatar
SB S10
94 s10
does anyone know if the steering column of a 94 s10 will interchange with a 93 on back to 82? i know the rear window will not interchange with any other model. does anybody know if there is anything else on a 94 model that wont?
Old 07-05-2007, 10:18 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
Err, dunno exactly what you are getting at. The 82-93 trucks are the same "body style" and share many interchangeable parts. 1994 was the first year of a major revision that changed about everything about the trucks. A 1994 S10 column is 1994 only because of no airbag. IF not for that it would be the same as a 1995.
BTW, the back glass for an S10 pickup fits from 94-04, also 96-00 Isuzu Hombres (Hollander Interchange).
If by chance you are instead talking about an S10 BLAZER/JIMMY then they ARE still the old body style. They weren't updated until 1995. They also have "94 only" steering columns, due to electrical connections I think. The back glass on them is interchangeable from 1991-4. If you use the older glass shocks and hinges you can bolt on 1990 and older rear glasses too.
Old 07-07-2007, 05:54 PM
runn141's Avatar
SB S10
[QUOTE=GypsyR]Err, dunno exactly what you are getting at. The 82-93 trucks are the same "body style" and share many interchangeable parts. 1994 was the first year of a major revision that changed about everything about the trucks. A 1994 S10 column is 1994 only because of no airbag. IF not for that it would be the same as a 1995.
If by chance you are instead talking about an S10 BLAZER/JIMMY then they ARE still the old body style. They weren't updated until 1995. They also have "94 only" steering columns, due to electrical connections I think. The back glass on them is interchangeable from 1991-4. If you use the older glass shocks and hinges you can bolt on 1990 and older rear glasses too.[/QUOTE
i bought an aftermarket back glass for a 94 s10 truck in 1996 they told me a 94 was a size all its own. would not interchange with any other model. now i heard the column was the same way i was just wanting a second opinion.
Old 07-10-2007, 12:27 AM
Wiki Edits: 11
Except for my thoughts about wiring connections being different in the columns the rest of my post is factual info from the nationally recognized "Hollander Interchange" system used by the majority of salvage yards so they can tell what really does fit what. Often even the car dealers parts department can't give you better info on what fits what. They have better parts listings but they aren't set up to really tell you "what also works".
Old 07-13-2007, 04:26 PM
runn141's Avatar
SB S10
the column wiring connections were what i was referring to
S10 to '49 Olds? grouch Suspension - Brakes - Steering 100 10-22-2010 04:57 PM
S10 truck transfer cases - 4WD to AWD curtis73 Transmission - Rearend 6 04-17-2007 03:22 AM
S10 frame help. matt167 Suspension - Brakes - Steering 15 07-28-2006 08:10 PM
S10 pickup or S10 Blazer frame? raj4851 Hotrodding Basics 10 01-06-2006 10:28 PM
Any advise on an S10? gt2betubbed Hotrodders' Lounge 7 08-07-2003 06:00 PM
