Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 94 s15 build
Thread: 94 s15 build
Old 10-14-2012, 06:19 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
Unless you have considerable experience with engine swaps and setting up driveline and suspension systems, I would not recommend using a BBC in this little truck. A well-built SBC will move it along in fine style. Here are 109 dyno-tested SBC combinations built with static compression ratios that will be compatible with pump gas. Take a look through them and you'll begin to see what works with what.....
Ryan's Stroker Combo Page (108 and up!)
If I lived close to you, I'd bring my sledgehammer over to your place and smash those 624 heads so that nobody would ever make the mistake of using them again.
Here's a conversion manual that I highly recommend you reading before you ever pick up a wrench......
http://www.jagsthatrun.com/Pages/Che..._S-10_V-8.html
The Following User Says Thank You to techinspector1 For This Useful Post:
nobody special (10-15-2012)
