94 Saturn trans-axle reverse drive problem
Can anyone tell me if there are any good forums or discussion boards on the net pertaining to the 1993 and later Saturn SC2 TAAT trans-axle?
My problem is when I put it in Drive or Reverse it won't move. First, second and third are OK. I have adjusted the shift cable and park/neutral switch still the same problem. When I am in drive or reverse if I pull back on the console shifter 1/16 inch the trans will drop into gear and go. One answer I found on the net is to look for the common problem of iron deposits in the valve body. I have ordered the manuals for the Saturn trans-axle to disassemble the valve body. Any helpful hint before I start working on it will be greatly appreciated. |
| GEAR DRIVE = DAMPER PROBLEM | bullheimer | Engine | 5 | 07-06-2006 12:09 PM |
| 1994 Saturn Transmision Problem | dmg53 | Transmission - Rearend | 4 | 01-18-2006 06:59 PM |
| TH200C trans problem... | shakyken | Transmission - Rearend | 2 | 02-24-2003 03:56 AM |
| OH MAN!!!!! HOSTON I HAVE A PROBLEM!!! I JUST LOST DRIVE!!!! | cuda66 | Transmission - Rearend | 5 | 11-21-2002 06:55 AM |
| 904 trans problem | 69 cuda resto | Transmission - Rearend | 1 | 09-24-2002 04:00 PM |
