94 suburban 350 into a 64 impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-29-2008, 02:15 PM
sccb1's Avatar
I am needing some help with my project. I have a 350 motor out of a 94 suburban into a 64 impala. My question is I am taking the TBI off and wanting to put a carb on it. Do away with the computer all together. Can I use the stock heads and an edlebrock performer rpm intake on it? Any mods I need to know about? I need to replace the dist. aswell, any suggestions on that. I am planning on running with the stock powerglide and rearend for now, any suggestions on a better combo in that area? Any input and or advice would be appreciated
Old 10-29-2008, 03:15 PM
SSedan64's Avatar
Those TBI heads are good for economy but not performance. As for a trans suggestion I'd go with a 2004R. It will swap right in most cars that came with a Glide. I'm not familiar with the Impala crossmember & frame mounting tho'. Most cars you can just slide it back but the Imp has an X-frame. I'm sure someone knows if it'll work. HEI Distributor.
Here's one site with parts to strengthen the dropout style rear.
http://www.bruneauperformance.ca/409...rendparts.html
Old 10-30-2008, 06:39 AM
sccb1's Avatar
Thanks for you input SSedan64. I appreciate all the help I can get. What is a good head for performance, not building a drag car but would like to have good power when needed.
64 Impala SS - Grommets 64Joker Body - Exterior 2 05-06-2007 06:00 PM
64 Impala SS Heater Repair 64Joker Interior 6 02-03-2007 04:56 PM
64 impala 4dr hardtop GCFDFirefighter Introduce Yourself 3 02-01-2007 05:36 PM
64 Impala Tire Size bamfasm Transmission - Rearend 2 07-22-2005 05:12 PM
I need help with 87' GMC FI 350 suburban bruceo327 Engine 2 02-24-2003 11:02 AM
