'94 Suburban Tranny Problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2009, 07:47 PM
I bought a '94 burban and I am feeling a bad vibration. It starts when I am in OD and downshift into drive. It almost feels like the driveshaft is out of balanced but not sure if thats the problem. When I put it in drive it does the same thing when it downshifts from drive to 2. Please let me know if it's something I can do or do I need a mechanic to look it over? Thanks Talonted
Old 05-11-2009, 07:57 PM
Does it only do it when you have to give it a little gas to get up an incline? If so, it is the torque converter doing it. What you are feeling is the converter coming unlocked. Mine does it too (96 suburban, 4L80E Auto). Not exactly sure why it does it, but it only occurs when the torque converter comes unlocked. Since that brings the RPM's up, it can easily be mistaken for a shift.
Old 05-11-2009, 08:06 PM
'94 Burban
Yes it does. It shakes the entire vehicle. I just give it more throttle just so it doesnt do more damage.
Old 05-11-2009, 08:14 PM
Mine only does it for a second while the converter is unlocking then it stops. But yes it vibrates hard. Kinda like running over those vibration strips on the side of the interstate, but a little worse.
94 GM Suburban Brake Problems DV8 Suspension - Brakes - Steering 3 02-02-2007 07:47 AM
tranny problems k1500_3 Transmission - Rearend 6 12-20-2006 06:18 PM
Low Idle Vacuum on 94' TBI Suburban edge Engine 4 07-21-2004 12:49 PM
Serious Tranny Problems DTL504 Transmission - Rearend 8 03-01-2004 08:19 PM
Carb vacum for tranny problems. kemo Engine 2 11-20-2002 06:15 PM
