94 Z71 TBI to carb. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2010, 09:30 AM
RLT-Z71's Avatar
Bullwinkle
94 Z71 TBI to carb.
Hi guys,
I am considering dumping the throttle body on my 94 5.7 due to tunning problems. It is an automatic. What will I have to do as far as the transmission is concerned?
Thanks,
RLT-Z71
Old 01-30-2010, 09:35 AM
Crosley's Avatar
Wiki Edits: 1659
Originally Posted by RLT-Z71
Hi guys,
Thanks,
RLT-Z71
the trans is electronic controlled..4l60e. you must have a TPS on the carb for proper input to the vehicle computer for trans control - shifts - pressure control.
If you are removing the whole computer system , the transmission will not shift, speed-O will not function, engine will run poorly unless you change the distributor
Old 01-30-2010, 10:55 AM
RLT-Z71's Avatar
Bullwinkle
Thanks Crosley,
Ok. Does Holly, Edlebrock, etc. sell what I need?
RLT-Z71
Old 01-30-2010, 09:14 PM
Last journal entry: headers
here you go
http://www.tciauto.com/Products/Electronics/default.asp
for the cost of the tcu you may want to consider swapping in a 700r4.
TBI to carb swap eatonde Engine 20 09-09-2008 11:01 AM
Low Idle Vacuum on 94' TBI Suburban edge Engine 4 07-21-2004 12:49 PM
TBI conversion to Carb Seon Engine 0 10-15-2002 03:20 PM
305 TBI to a 305 carb engine swap 91olds305 Engine 1 10-14-2002 11:48 AM
305 TBI to a 305 carb engine swap 91olds305 Engine 0 10-14-2002 10:10 AM
