Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 350 tbi no start
Old 05-06-2012, 04:36 PM
Ded0nfeet Ded0nfeet is offline
Thanks for the reply, I've tried getting the timing as close as possible (#1 plug removed, valve cover removed to ensure without a doubt I was on compression, even used a scope to make sure the piston was at tdc) the balancer seems right on, when I had the light on #1 I couldn't see where it was firing at all. I know some part of the system is working because the injectors pulse when the dist is turned, is there anything that would cause the spark to be intermittent? Do you know what wires/sensors/parts I should test for failure? I just dont have enough experience to diagnose this issue without good instruction, the sad thing is if it was a 07+ cat diesel it would be running down the road already. Thanks again for the help
