95 454 with older aluminum head - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2013, 02:32 PM
i have a 95 454 rebuilt studded head bolts and crank, stock rods stock piston std. bore, 077 aluminum heads, .595 .621 solid lift cam......? is what is the best head gaskets to use for this application. some say felpro 1037 and some say victor reins. who has done this and had great success,with what gaskets?
Old 06-19-2013, 06:34 PM
BOBCRMAN@aol.com's Avatar
I have used either on late BBC short blocks. I use ProComp aluminum heads which are designed like early BBC.. I prefer the Victor-Reinz. They stick to block surface well. I have never had a leak or failure with either gaskets. Victors are just a pain to clean off, if service is needed..
Old 06-19-2013, 10:28 PM
what are part number/s that you have because i read somewhere there different ones for each side of block with victor reins and i hear the victor reins are used with a bigger bore block 502 ect...mine is std.also u have used felpro 1037 with no problem and just want to know why u prefer victor gaskets
049 corvette 454 heads vs new aluminum. KMPJ-93 Engine 6 12-09-2012 05:02 PM
Aluminum heads leaking on 454 skidderking Engine 23 11-28-2010 08:05 PM
external balance 454 aluminum flywheel dman16 Engine 0 03-27-2009 12:02 AM
aluminum head id? chevelle4542speed Engine 1 04-13-2006 07:41 PM
what is the BEST aluminum head out there? rick458 Engine 52 04-06-2006 06:59 PM
