95 Camaro 4L60e in limp home mode - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2011, 07:09 PM
I started having this prob. about a month ago. I replaced the TPS and thought it fixed the prob. nope. I have now replaced the 1-2 solenoid , removed and tested the internal wiring harness. I do not have any error codes. any ideas. How hard would it be to just swap to a th350 and a SBC.
Old 12-30-2011, 07:19 PM
tnsmith10's Avatar
when will it rain???
from what you described, it sounds like the trans is not getting voltage. start checking for blown fuses.
a sbc and a th350 is possible but definitely not worth doing on a DD, and is a lot of work and some fabrication involved.
06 Denali Limp Mode 123pugsy Transmission - Rearend 11 03-10-2010 08:17 PM
4L60E Limp Mode hardwurkindaddy Transmission - Rearend 4 11-14-2009 09:29 AM
Camaro home from painter ... sune Body - Exterior 2 04-20-2004 05:02 PM
ill post camaro pics when i get home Rubberman2003 Hotrodders' Lounge 2 08-17-2003 06:21 PM
