Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 Camaro engine swap
Old 12-18-2004, 11:45 AM
willys36@aol.com's Avatar
willys36@aol.com willys36@aol.com is offline
Wiki Edits: 21
Welcome to the board. Since you are new here, I suggest you read the "Read Me" threads at the top of many of the forums to see how they are set up. For example, this forum is intended for "Howdy" introductions only. Tech questions should not be posted here, rather they should be posted in the appropriate Tech forum ("Engine" in this case) so they will ge the best exposure to the experts.
