I have a 95 camero I just put a clutch in an now the clutch pedle feels like there is air in the line but the system was never open for air to get in. I tryed just pumping the clutch for two days and it still only works if I pump it up then shift then pump it to go to 2nd so on and so on. If anyone has a suggestion please let me know its my daily driver and I need to get it back on the road. Thank you.
BST is right. If you have to pump it, most likely it either just has air in it or the m/c is bad. That is provided the parts that you installed are the right ones. I have seen where the disc or pressure plate were wrong and caused this. The fingers on the pressure plate can be too far in from a disc that is too thick or pressure plate with not enough off-set. This causes the release bearing to have to travel further to release the clutch. Also a flywheel that is supposed to be undercut, being machined wrong has the same effect. I am not familiar with that flywheel, so I don't know if that applies here.
I hope that isn't why you changed the clutch. |
