95 camero trans for a 99 Sonoma??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2010, 10:35 AM
Shag0215's Avatar
Tha Shag
I have a 1995 Camero RS 6cyl, motor has 212,000 miles, so its about gone. I also have a 1999 GMC Sonoma, same motor as Camero, but reverse has went out. Does any one know if the transmission from the camero will bolt n work on tha Sonoma??? I believe there tha same transmission, both have OD, not to concerned about a gear difference, jus need a moving ride! Any feedback will be helpful. Thank you for your help and support.
Old 08-12-2010, 10:45 AM
tnsmith10's Avatar
when will it rain???
it is the same trans, but i dont recall seeing a camaro come w/ a 4.3 (90*) like your sonoma. and in the same aspect, have not seen a sonoma of that year with a 3.4, or 3.8 (60*) that comes in those years camaros, so the bell housings are different. other than that, there have been quite some electrical changes done between 95 and 99 and even if the cases were the same, the unit will not work properly.
Old 08-12-2010, 01:05 PM
big gear head's Avatar
High Performance Rear Ends
The '95 Camaro (no E in Camaro) will have the 3.4 V6 and the S10 will probably have the 4.3 V6. These are not the same engine and the transmissions will not interchange. The 3.4 is a 60 degree engine and the 4.3 is a 90 degree engine.
94 to 95 Ford Taurus engine and trans swap 406chevelle Engine 6 11-20-2005 02:14 PM
AOD into mustang Stangman196700 Transmission - Rearend 3 12-16-2004 08:51 PM
95 Trans Am question valenciastudent Transmission - Rearend 1 09-13-2003 09:06 AM
loner trans shift cable for 95 tbird bob miller Hotrodders' Lounge 0 07-01-2002 04:55 PM
'95 LT1 w/ 700R trans Dirtbag Engine 3 04-10-2002 04:16 AM
