'95 Chevy 1500 ring and pinion - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2010, 03:53 PM
Wiki Edits: 31
not really a hotrod, and not my vehicle ( but might become mine ).. '95 Chevy 1500 extended cab, 4x4 5spd. V8 ect.. really nice shape except it needs a ring and pinion.. for $800.. actually nice enough I drove by twice and thought it said $8,000. and only the last time, noticed it was only $800.. it's also just down the road from my house... don't normally like Chevy trucks '88-'98 but, it would do what I need, and it is nice for a Chevy
The Zr2 S10 rear I have for my hotrod is a 8.5 10 bolt 3.73 w/ gov lock carrier.. would that carrier swap in easy providing the truck has 3.73's? or should I just go to a U pull it and swap another rear in it, with the right gears?
Old 11-01-2010, 06:57 PM
Wiki Edits: 31
well, Mods could possibly move this into transmission/ rearend... because the truck is mine
Old 11-02-2010, 11:01 AM
Wiki Edits: 31
1980 Buick Lesabre Ring & Pinion Bull_81073 Transmission - Rearend 6 05-24-2009 09:50 PM
Setting ring & pinion, chevy 12 bolt BUFFALOBILLPATRICK Transmission - Rearend 10 11-23-2008 09:48 PM
Need Help Installing Ring & Pinion in 9" Ford S10 Racer Transmission - Rearend 5 04-21-2008 02:27 AM
Changing pinion bearings on Chevy ILLJim Transmission - Rearend 3 05-23-2007 09:42 AM
12 bolt Chevy truck pinion question Gametech Transmission - Rearend 9 03-09-2004 06:02 PM
