95 Chevy 2500 4x4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2009, 01:08 PM
123pugsy's Avatar
Last wiki edit: Metal shaping
Wiki Edits: 29
95 Chevy 2500 4x4
I just got a call from a guy with a weird problem.
He says he starts his truck up and its like its in Drive.
The speedo starts moving as its still in Park.
If he shifts to Drive it doesn't move although when he puts it back in park he hears a grinding or ratchetting sound.
The VSS would be located in the transfer case on a 4x4, correct?
Output shaft turning in Park?
Any thoughts?
Old 10-01-2009, 02:08 PM
sqzbox's Avatar
My pipes are my music
I don't know what model transfer he has but I would suspect the transfer drive chain is broke. What does it do when he puts it 4 wheel drive?
Old 10-01-2009, 02:17 PM
123pugsy's Avatar
Wiki Edits: 29
Oh yeah.
He said it moves about 10 feet and then stops and freewheels.
Old 10-01-2009, 04:19 PM
sqzbox's Avatar
Transfer case problem. Not VSS.
Old 10-01-2009, 05:08 PM
tnsmith10's Avatar
when will it rain???
or differential. the output shaft on the t-case is where the vss gets it signal. it could be t-case, but if the speedo is moving when in gear and its not going anywhere, then the drive shaft needs to be watched to verify whether its t-case or rear diff.
Old 10-01-2009, 06:10 PM
123pugsy's Avatar
Wiki Edits: 29
The speedo is going when its in Park.
He mentioned something about recent diff work.
1984 chevy 4x4 gear question pi71 Transmission - Rearend 2 12-04-2008 07:56 PM
95 chevy blazer supermansls Engine 1 10-21-2007 08:28 AM
1967 Chevy 4x4 Conversion 53chev Transmission - Rearend 1 03-24-2006 06:29 AM
swapping a 700r4 with a turbo 350 on 4x4 chevy trucklover Transmission - Rearend 3 12-22-2002 06:39 PM
4x4 chevy jimmy stuck in 4 whl drv speedpro Transmission - Rearend 4 11-19-2002 02:06 PM
