Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 Dakota 2.5L 4cyl. Runs Rough Help!
Old 06-13-2006, 07:00 AM
1931 steve's Avatar
1931 steve 1931 steve is offline
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
Is this thing blowing black smoke out the tail pipe? How much coolant went into the exhaust system? The oxygen sensor has more than likely failed due to coolant contamination, I would start by replacing the oxy sensor. Also check your vacuum going to the MAP (manifold Air Pressure) sensor. Try running it with this sensor unplugged. Are you sure it is a code # 34 that is flashing on the dash?
Steve
