Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 Dakota 2.5L 4cyl. Runs Rough Help!
Old 06-13-2006, 12:37 PM
sbchevfreak's Avatar
sbchevfreak sbchevfreak is offline
Licenced Automotive Technician
Originally Posted by 1931 steve
Is this thing blowing black smoke out the tail pipe? How much coolant went into the exhaust system? The oxygen sensor has more than likely failed due to coolant contamination, I would start by replacing the oxy sensor. Also check your vacuum going to the MAP (manifold Air Pressure) sensor. Try running it with this sensor unplugged. Are you sure it is a code # 34 that is flashing on the dash?
Steve
These are prone to MAP problems, as well as wiring gremlins. This might help...
Originally Posted by ALLDATA
Circuit K6 splices to supply 5 volts to the throttle position sensor.
Circuit K4 splices to supply ground for the signals from the following:
Heated oxygen sensor
Distributor Pick-up coil
Throttle position sensor
Manifold absolute pressure sensor
Engine coolant temperature sensor
Throttle body temperature sensor
I got the MAP diagnostic charts off ALLDATA, and uploaded them. HTH
Freak
Name:	95 Dakota MAP diagram.gif
ID:	12744   Click image for larger version
Name:	MAP diagram testing1.gif
ID:	12745   Click image for larger version
Name:	MAP testing 2.gif
ID:	12746   Click image for larger version
ID:	12747   Click image for larger version
