-   -   95 Dakota 2.5L 4cyl. Runs Rough Help! (http://www.hotrodders.com/forum/95-dakota-2-5l-4cyl-runs-rough-help-91581.html)
TT66' 06-12-2006 07:51 PM
Engine runs fine for 30 seconds then check engine light comes on and loses power, runs rough and wants to die. As soon as you shut it down let it cool off, then start it backup same deal happens. All things temp. , oil press., charging system all appear normal during all this. Any ideas where to start looking or give in and find someone with scanner? Also, how do you reset the computer? Just by unhooking battery cable?
Any suggestions? :( Can anyone help?
Thanks,
TT66'
97Z28 06-12-2006 08:22 PM
sounds like it could be your ignition module heating up..... ? not too familiar with the dodges. sorry...
1931 steve 06-12-2006 08:56 PM
Check your fuel pressure. Does your exhaust flow well from the tail pipe (poss plugged cat converter :confused: ) Is the exhaust temps very hot? Does it stall or just run rough?
I will try to look up more info on this in the morning when I get to the shop.
Steve
TT66' 06-13-2006 04:03 AM
I haven't checked the fuel pressure, but i took the converter completely off and by passed it. If you keep the RPM'S up it will run longer without cutting out, but when you let off to idle it it starts running rough. The only way to keep it running is to pump the gas, but it will eventually stall. According to the readout that flashes on the speedometer it's#34 which say's it is either the speed control vacuum or vent control solenoid circuits. It doesn't have cruise control so that rules out the speed control vacuum. I found out that the vent control solenoid controls the vacuum from the fuel cannister to the throttle body. I swapped out 3 different control solenoids and that make any difference. I also checked every vacuum line on the engine with a vacuum pump and found no leaks. I didn't the lines running to the gas tank, but there all metal running from the engine back to the tank.I had a busted head gasket before this all started and antifreeze got into the muffler and exhaust system and it wouldn't hardly run.That's why im wondering if the computer needs reset. Ive had the battery unhooked several times and it don't seem to make any difference. I haven't worked on the newer computerized dodges any and if I get this one running it will be the last one I ever own or work on. Any info you can give me will be greatly appreciated. Thanks for your time and interest.
TT66' 06-13-2006 04:08 AM
reposted that last post. my bad.
1931 steve 06-13-2006 07:00 AM
Is this thing blowing black smoke out the tail pipe? How much coolant went into the exhaust system? The oxygen sensor has more than likely failed due to coolant contamination, I would start by replacing the oxy sensor. Also check your vacuum going to the MAP (manifold Air Pressure) sensor. Try running it with this sensor unplugged. Are you sure it is a code # 34 that is flashing on the dash?
Steve
sbchevfreak 06-13-2006 12:37 PM
5 Attachment(s)
Steve
These are prone to MAP problems, as well as wiring gremlins. This might help...
Originally Posted by ALLDATA
Circuit K6 splices to supply 5 volts to the throttle position sensor.
Circuit K4 splices to supply ground for the signals from the following:
Heated oxygen sensor
Distributor Pick-up coil
Throttle position sensor
Manifold absolute pressure sensor
Engine coolant temperature sensor
Throttle body temperature sensor
I got the MAP diagnostic charts off ALLDATA, and uploaded them. HTH
Freak
TT66' 06-13-2006 03:05 PM
Thanks for the info. This will be a good start any other info will be appreciated.
