'95 F-150 distributor problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2011, 11:23 AM
kinda my last resort here, Ford truck club won't let me in ..... '95 Ford f-150 with 302, has the fuel system with 4 injectors..... how do I check the distributor ? All was good , till I changed the dist due to a bad bearing. Then the truck quit on me, checked out the ign modual on the fender, was bad, with the new one it ran about 3 days, quit again , won't start. Modual checks out good this time... I have no spark and none to the injexctors....how do I check the signal thing in the distributor ? I think it's a P I P signal ? thanks
Old 04-30-2011, 04:40 PM
techinspector1's Avatar
Wiki Edits: 326
If you want to work on it yourself, then you may want to buy one, some or all of these manuals. These are original Ford manuals and in my opinion, are the only ones to use. Those Fosdick aftermarket clunkers are worthless. I guess this new EFI and all the gizmos is good for the planet, but it can sure wreak havoc with your wallet. You may come out with a cheaper and quicker fix by letting someone else fix it for you. I spent a ton of money on Faxon original manuals and tools to find the problems with my '91 Ford F-150 4.9 liter. Runs good now, but it SHOULD run good, for all the sheckels I spent on it.
http://www.faxonautoliterature.com/Search.aspx?c=121226
Old 04-30-2011, 04:41 PM
LATECH's Avatar
test the pickup coil resistance with a DVOM.Spec should be between 400-700 ohms.
And X 2 what Techinspector said.. Clymers , haynes and chilton are all useless. They dont even make good TP.
Old 04-30-2011, 05:41 PM
I do have some of the Ford manuals , but the 1 I don't have the one that includes the electric trouble shooting stuff ! I'm going to get that one now , as I can see how complicated this ''new'' stuff is.....I agreee about the chitons , it said my fuel pressure was suppoed to be only 17 pounds ! ( instead of 35 to 40 )..............Anyway , I checked the dist, , replaced the dist, started right up ! This dist (rebuilt NAPA) was only in it for about a week ! NOW, I just wonder how long this one will last....where it will leave me stranded ????????? thanks guys !
Old 04-30-2011, 05:54 PM
Wiki Edits: 326
On 307-A Bypass halfway between Hogjowl and Fiddler's Corner at 2:00 A.M. Oh, and by the way, there's no cell connection out there.
Old 04-30-2011, 09:12 PM
how well I know that feeling ! About a year, traveling with my old motorhome (over 20 years old and 100,000 plus miles on it ) I like to travel at night..... all of a sudden it quit , 2 AM on a 2 lane road ! And I STILL have no idea where it was ! Luckily it did start right back up , and I never slowed down till daylite !
Old 04-30-2011, 09:29 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
No columns of intense white light coming from a strange flying disc above, right?
Guages didn't go crazy, and the radio didn't quit either?
69 Chevelle distributor problem boone44 Electrical 3 09-30-2009 07:41 PM
Odd distributor problem falinman Electrical 10 01-08-2007 12:43 AM
distributor problem charliec Hotrodding Basics 8 09-06-2005 09:17 PM
352 Distributor problem...please HELP!!! tazzman68 Engine 3 01-28-2005 07:38 PM
HEI Distributor Problem Jag Daddy Engine 3 11-07-2003 12:48 AM
