Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 95 ford F-150 engine swap, Same Transmission fit new engine?
Old 10-07-2007, 12:58 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Ford 300 6 cyl engine uses a small block bolt pattern on the bell housing. You have to have an engine that fits the bell housing.
Check crank shaft pilot on the torque converter for correct size to fit the replacement engine. Check bolt pattern for the flywheel to torque converter stud pattern.
