95' ford ranger 2wd rear brakes locking up - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-16-2009, 07:23 AM
I have a 95' ford ranger 2wd rear abs with the rear brakes locking up, and the abs light stays on all the time. I already replaced the differential sensor, and front and rear brake pads replaced. Now the the abs light is on and off sometimes, and when I come to a stop, the brakes seem to chatter. Has anybody had the same problem?
thanks
Old 02-16-2009, 09:52 PM
ive had the same problem with a suberban and a malibu b 4. try first off checking your fuses(sounds dumb but had to put it) then bleed your brakes and make sure you have a good flow through your lines. even if you do you might want to check your lines n e ways. i had a bent line after loning my car to someone and they drove over a good size rock on the freeway that skipped up and hit the line pretty hard.
hope it helps
Old 02-21-2009, 05:38 PM
Mr.NutCase's Avatar
Check for dirt around the ABS sensor, and pull the codes with ABS scanner
98 Ford Ranger rear end install posi trak? Bubblehead Transmission - Rearend 9 12-14-2008 03:48 PM
rear disc brakes, ford 9" readdirections Suspension - Brakes - Steering 6 09-08-2006 08:16 PM
Ford Ranger V8 Conversion izzymiddleton Hotrodders' Lounge 13 11-14-2005 11:23 PM
1945 ford p/u rear leafs,to keep or not to keep biglee550 Suspension - Brakes - Steering 8 04-25-2005 07:05 PM
Ford Ranger 8.8" Rear Disc Brakes nightrain_rod Transmission - Rearend 1 06-23-2003 05:48 PM
