95 GMC Safari auto trans "SLAMS" into drive
Starting out from a stop the automatic transmission in my 1995 GMC Safari "SLAMS" into drive. After its in drive it works just fine. It will also slam out of drive when i stop. Whats up?
I would think its going to be the trans. mount or U joints.
From your post I am guessing the transmission drops out of gear when you stop? The trans seems to go into "neutral" after you stop the vehicle, then as you step on the gas pedal the trans "bangs' into gear then moves? Mileage on this transmission? Any recent work or service of the fluid? ![]() Sounds like low fluid or a worn out transmission
At the Bonneville Salt Flats, first gear is known as 130 mph. |
| 95 gmc jimmy fuel pump won't shut off/fuel pump relay | garystrosnider | Electrical | 7 | 10-28-2010 07:10 AM |
| more 95 gmc jimmy woes | ChevyJim | Electrical | 4 | 07-09-2006 04:24 PM |
| need some advice about a 95 GMC Jimmy | ChevyJim | Suspension - Brakes - Steering | 14 | 04-23-2006 09:18 AM |
| need help finding TDC and some other things on my 95 GMC 350 | warren35095 | Engine | 2 | 04-28-2005 10:19 PM |
| GM Auto trans identification help? | Pantera II | Transmission - Rearend | 1 | 12-02-2002 04:02 PM |
